EMS V86 Problem
First post, by xarxas
The latest ykhwong CVS build can't run Autodesk Animator Pro. It just crashes.
Enabling EMS and XMS, i get the following message:
"Bad EMS emulator -- reports VCPI but doesn't use V86 mode"
Instead, DOSBOX 0.63 works perfectly.
Reply 2 of 2, by xarxas
If I turn EMS off, DOSBOX crashes without any error message...
I can send you AAPRO, if you want.
