First post, by PooshhMao
Hi,
I use a Litestep-based shell with a dosbox frontend built in.
Every DOS game has it's own .conf file, with the autoexec section launching the game. Apart from that, the rest of the files are mostly identical (save for some differences in cycles and such). Is it possible to launch DOSBOX with two config files (the first one being the default, the second one with game specific settings)? This does not seem possible using the command line...
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
nope that isn't possible.
although DOSBox itself works that way.
you only have to save the changes you make to the configfile.
not the the total one.
Water flows down the stream
Reply 3 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
yes, AFAIK, this is how it works.
Pooshh, you can also set a lot of settings in bat files since 0.65. I have a run.bat in each of my games folders, that set core and additional needed mounts (iso files for example).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 4, by rcblanke
Hi all,
I've made a small and simple patch (for CVS or v0.65) that will allow for multiple Dosbox config files. Simply start dosbox with more than one -conf parameter, like so:
dosbox.exe -conf dosbox.conf -conf dosbox2.conf -conf dosbox3.conf
That will apply the setting from dosbox.conf first, then override the settings specified in dosbox2.conf, and finally those in dosbox3.conf. Please note that autoexec commands are cumulative.
I'm attaching a patched CVS binary for convenience as well, for those who are not able to compile it themselves.
Regards,
Ronald
    addconfpatch.diff
    452 Bytes
    155 downloads
    patch for multiple conf files
    dosbox.zip
    666.71 KiB
    151 downloads
    Win32 patched binary
