Theme Park
First post, by mjhardisty
Is Theme Park runable under DOSBox 0.65 - does anyone have a setup for it?
Reply 2 of 7, by mjhardisty
I've tried with a standard setup, and it hangs on the initial DOS protected mode start. Not sure whether this is the movies or not. I was just wondering if anyone had it working.
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well It used to work fine. Been a while since I tried it though.
Water flows down the stream
Reply 5 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
hmm I just started it with 0.65
ran fine.
Reply 6 of 7, by mjhardisty
What settings did you use differnet to default?
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
I did default
Game was configured to use soundblaster pro.
