Cursor key problem
First post, by red_avatar
Using ykhwong's Dosbox version, my cursor keys behave exactly like the numpad keys - if numlock is on, if I press up or down, I get 8 and 2. Is there any way to fix this?
Reply 1 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
usescancodes in dosbox.conf
1+1=10
Reply 2 of 4, by red_avatar
Ahah! That worked 😀 thanks a lot!
Reply 3 of 4, by red_avatar
Actually, it did do something else: DOSBOX used to have the american QWERTY keyboard layout which I'm used to and now, oddly enough, it is partly AZERTY and partly QWERTY which is extremely confusing.
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
hmm You need to try a clean cvs build.
you reported on irc a lot things on which we didn't change that much 😀
It would be interresting to compare if they were really fixed or really broken 😀
Water flows down the stream
