First post, by jez
Hi, I'm trying to install the Daggerfall 2.13 patch, and there's a problem. It unpacks and prompts me to install the FIXMAPS patch. It says it'll need to install the maps.bsa file from CD. It then tells me to insert my Daggerfall CD, again and again.
The thing is, my Z.CFG has my path and pathcd set to c:\games\dagger\arena2\ which is where my CD files are copied to. The game itself works fine. maps.bsa is in that directory. I've tried putting the actual Daggerfall CD into both my CD drives too, no change. Why can't this stupid patch find maps.bsa??
Update: Now the game doesn't seem to be running either, it crashes. Oh bother.
Also, FIXSAVE gives me the same insert CD prompt.
== Jez ==
Reply 1 of 1, by jez
Oooooooops, ignore this. I was retarded and renamed the Daggerfall directory but forgot I did it. Working now.
== Jez ==
