First post, by Roxor
I tried capturing a fair bit from Under A Killing Moon, and even with the video set to original and no scalars, the text for subtitles is slightly messed-up.
What I'm wondering is whether the problem lies in the ZMBV codec, or DOSBox's internal encoding. Under A Killing Moon does run using a VESA resolution (of 640*480*8bpp), so perhaps the capture of frames for encoding is buggy?
I've also tried Stargunner, and that has messed-up text if scalars are enabled (it also uses a VESA mode, this time of 320*240*8 ).
And, surprise, surprise, the red and blue are switched in playback of both recordings under x64 Windows.
Reply 1 of 1, by romantic
Read my posts here, may be it will help.
To be happy, just make the others feel the same way!
