Choppy on most games
First post, by Bumblebee Tuna
I'm sorry for my newbieness, but I have a few questions about some games I'm trying to run on Dosbox.
It seems like WC3, Under a killing moon, and phantasmagoria, can be quite choppy while I'm playing the games. I've been trying to correct this, but I don't seem to have any luck. Can anyone suggest things that I can do to help reduce the choppiness? And if you answer, do it step by step instructions. I'm a meganewbie here., 🤣
Thanks.
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Tell us what you have tried. We hate wasting time suggesting things that people have already tried.
_________________
Reply 2 of 5, by Bumblebee Tuna
It seems like it has something to do with my CPU. For example, when I installed WC3, it said I had a fair CPU speed. Now I adjusted the cycle to Auto, and it seems to have helped, a lot. I'm not sure what would be a good setting to have it at. If this helps, I have a 1.6 Gz P4 processor. Anyone know what cycle would be good for it?
Reply 4 of 5, by Bumblebee Tuna
So, what you're saying I should use my AMD 64bit 3200 processor, with my pci-x video card? If I do, do you know what I could set the cycle to roughly?
Reply 5 of 5, by Lofty
Best setting varies from game to game. Auto is meant to take the guesswork out, but it may not be optimal - I prefer to just set it manually and increase it gradually with Ctrl F12 until the game is as smooth as possible. Setting frameskip to 1 can also be good, especially for 3D games. I think those are all very demanding games though. Dynamic core will almost certainly help.
