First post, by Martenzo
The issue is, that I can\t find it, I'm using linux, and all toturials tell me to change EMS/XMS in dosbox.conf but none of them tell me where it is in linux.
Reply 1 of 7, by eL_PuSHeR
Type this inside DOSBox...
Z:\>config -writeconf dosbox.conf
to generate a new configuration file.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 7, by Martenzo
And it loads the conf file if it's in /home/username/ right?
Thanks
EDIT: Got it working, but there's another problem (same game Zone 66)
It claims to have too less extended mem (needs 512K), but the mem max is set to 50 Mb in the conf.
Reply 3 of 7, by DosFreak
Alot of DOS games don't like having tons of memory because they do not recognize such a high value. Try DosBox with the default memory size of 16 and see if that works. If not then lower ir further.
Make your games work offline
Reply 4 of 7, by DosFreak
Also you may be confusing conventional memory with extended memory (or the game is). I'm betting that 512k is the amount of conventional memory the game needs and you have too much. So try running "Loadfix" as well which will eat up some conventional memory so the game will see a lower conventional memory value.
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
The game neess xms=false AND ems=false.
Extended memory here refers to the installed raw memory
(int15 interface), and if some emm is loaded it removes
that memory from the int15 interface.
Why 50??? You're best off with the default of 16mb.
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
If you're using an untouched dosbox.conf, the only things needed to
be modified are xms=false and ems=false. If the game works then,
you can edit the core/cycle settings and others as you like.
Feel free to report back if it works/doesn't work for you.
