First post, by Dmitri
I'm looking for older versions of DOSBox--0.61 and 0.63, specificly. I'm trying to run the original MechWarrior game, which crashes in 0.65; according to the list on the DOSBox site, those two versions will work with it. I know the old versions are available from the downloads page as source code, but I'm not sufficiently savy do anything with that. Alternatively, if someone knows a way to make 0.65 run MechWarrior, I'd be all for that, as well. Thanks for your help.
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
I though mechwarrior ran in 0.65 anyway
http://sourceforge.net/project/showfiles.php? … ackage_id=46709
Water flows down the stream
Reply 2 of 4, by Dmitri
That page is links to the source files; unless I'm misunderstanding, that means they're not runable as-is, but require compilling (feel free to correct me if I'm wrong).
The problem that 0.65 has with Mechwarrior is fairly specific--it can't end battles. It chashes instead. Everything else works fine.
Anyhow, thanks for the link. I'll try posting over in teh specific games area, and see if there's already a solution to my problem.
