First post, by t0maz
Hello,
I'd like to get IPX networking to work so I can try to login to a Netware server. Unfortunately I haven't found a page in the documentation which describes how to do this so I'm just kinda doing something here. First I enabled ipx in the config file. Next, I'm trying to load the (what I think) required stuff:
LH LSL.COMLH RTSODI.COMLH IPXODI.COMLH VLM.EXE
That's what I think I need to do and then it would work. But while trying to load the Realtek driver (RTSODI.COM) I get the following errors on the screen:
Realtek RTL8139/810x Family Fast Ethernet MLID v3.66 (031231)(c) Copyright 2002, by Realtek Semiconductor Corp. All rights reserved.Max Frame 1514 bytes, Bus ID 4Board 1, Frame ETHERNET_802.3, LSB ModeRTSODI-DOS-30: This is not on a PCI system.RTSODI-DOS-6: The adapter did not initialize. RTSODI did not load.
Any suggestions on how to get IPX networking to work?
