CAPS LOCK?
First post, by mcs1234
Is there a way, either in CNFG or elsewhere, to cause DOSBOX, when started, to turn CAPSLOCK on for the DOS session being started?
I see the keymapper values, but those look mostly like "re-assignment" settings, and I don't want to reassign the key, just cause it to be turned on when the DOSBOX session starts.
Any ideas? Thanks,
Doug
Reply 1 of 3, by Gwhite
If you use (or can use) a batch file to start whatever program you want to run, there used to be small utilities that would do this. The ones I use are CAPSON.COM and CAPSOFF.COM. You should be able to find them in an archive some place, or you can send me a note and I can send you a copy.
