First post, by darkphen
Hi, i'm in charge of a windows to linux migration.
For this there is an old program in DOS that have to work.
This program use a old btrieve database and have to be accessed through a requester.
There is 2 versions for DOS, one with TCP that requiere a TCP stack (a total mess and impossible with DosBOX) and another with IPX/SPX.
When i try to execute, the initialisation is OK but i get a error saying : SPX is not supported on this workstation.
Of course i set the IPX support to true.
I play with the ipxnet tools, i'm able to start a server but not to connect. I'm using dosbox 0.65 under a Ubuntu 6.06 Dapper.
I also try qemu, and dosemu (same problem), but i'm not lucky with those tools too.
What can i do? have i to set something in linux to support the spx network? How does the ipx/spx calls work?
Thanks.
Reply 1 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
1. Make a "native IPX" for Linux. The "normal" Dosbox does not touch the IPX/SPX stack of the host but uses UDP tunneling. (I have one for Windows but nobody uses it).
2. If you really need SPX you have to implement:
Int 7A/BX=0011h - Novell NetWare - SPX Driver - ESTABLISH SPX CONNECTION
Int 7A/BX=0012h - Novell NetWare - SPX Driver - LISTEN FOR SPX CONNECTION
Int 7A/BX=0013h - Novell NetWare - SPX Driver - TERMINATE SPX CONNECTION
Int 7A/BX=0014h - Novell NetWare - SPX Driver - ABORT SPX CONNECTION
Int 7A/BX=0015h - Novell NetWare - SPX Driver - GET SPX CONNECTION STATUS
Int 7A/BX=0016h - Novell NetWare - SPX Driver - SEND SPX PACKET
Int 7A/BX=0017h - Novell NetWare - SPX Driver - LISTEN FOR SPX PACKET
(copied from Ralf Brown's Interrupt List)
Reply 2 of 9, by darkphen
So i just have to set the IPX stack on linux, for DOSBOX behaving like it has a IPX stack under DOS ?
Sorry but i'm developping, i don't know what to do with these calls...
Do I need an SDP driver?
Reply 3 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
It has to be implemented in Dosbox source code.
1+1=10
Reply 4 of 9, by darkphen
So like the SPX calls are not implemented, isn't there a way to catch them with a IPX/SPX driver? i read somewhere that novell used to have a IPX.COM file to launch. Nobody have an idea? :s
Reply 5 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
IPX.COM needs a NIC driver and a NIC driver needs a NIC. Dosbox does not have a NIC.
1+1=10
Reply 6 of 9, by darkphen
OK thanks, the problem is that is the same for Dosemu, both have an IPX support but doesn't have SPX supported either TCP...
Nobody knows a way to have an IPX/SPX support or a TCP support with a dos emulator under linux?
Last try 🙁
Reply 9 of 9, by darkphen
I managed to get Dosemu working with TCP.
The problem is that it doesn't have NIC but an integrated driver packet. So for example Waterloo TCP apps are working.
Since i still need a TCP stack to get my btrieve app working, i don't know what to do... MS Lanman need an NDIS driver...
Same result with LAN Workplace by Novell, both are especting a hardware driver to run.
Forget about IPX, the btrieve server use TCP.
I will try qemu, i will post my results to help people, if they have the same problem than mine.
