First post, by rsolow
I have tried using DosBox (.65) with and without D-Fend (and with and without "Game Needs Loadfix)
In the DOSBOX STATUS WINDOW, I am getting a dos window full of "illegal write to" and "read from" errors followed by a "CPU SetSeg General: stack segment beyond limits: error msg
In the DOSBOX CPU Cycles Window, I get the following error msg
Call FG. bat ]<-- this is what I assumed to be the program I am supposed to run to get FG up and running]
CD exe
Unable to Change to exe.
Any suggestions would be appreciated.
RSOLOW@Comcast.Net
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
Maybe you can post the full contents of the (executed and called)
batch files.
Also try with xms and ems disabled.
Reply 2 of 4, by AlleyKat
(Old topic, but...) Hmm strange. I have it running perfectly, almost.
The intro sound is missing and the game behaves weird in the island in-betweens (it seems to go on a short coffee break each time), but all gameplay plus (importantly enough) game load/save seems to run perfectly.
I did a full install on to C:\FG\ and the dosbox conf looks like this:
fullscreen=true
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
machine=vga
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=normal
cycles=3000
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
…Show last 28 lines
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[bios]
joysticktype=2axis
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
[ipx]
ipx=false
[autoexec]
mount C "C:\FG\"
mount D "G:\" -t cdrom
c:
cd \FG
It's pretty much default except for the fullscreen and the autoexec commands. It doesn't launch the game - first time it's run, you should run the sound setup first, choose Soundblaster and Autoconfigure, and save that. Then run the game with fg.bat - works for me.
Change drive G: there in last mount to your CD drive.
(Hardware is an Abit IntelP4 775 mobo with Realtec AC'97 5-ch sound, nvidia as-small-as-they-come pci-e gfx, and an original Fantasy General CD if this could make a difference)
Just as weird, the missing intro music & storytale actually works if I just run it in an XP cmd box. That is, however, all that happens - I can't even find the running process for it, it just plays the sound and... disappears.
Reply 3 of 4, by catchaserguns
Is it a Cd game or a ripped game?
Reply 4 of 4, by AlleyKat
CD game (fully original) as stated. 😀
It will be a ripped version when I figure out what software to use; the cd's so scratched that the music doesn't even play so I need something to rip it over and over until it gets it right I guess.
Real shame; part of this games appeal is the way cool choir music.
