First post, by Aidan1234
I just downloaded the Dos Emaluator 0.65 and Ran the Game Twinsens Odyssey. I couldn't save though, so i tried installing it, and it told me that it could not acess a subdirectory recquired to install the game.
Basically it couldn't make the folder 'Twinsen' in My C drive.
i then created the folder on my own, and then told it to acess that folder, but that didn't work either. It told me that the path specified couldn't hold a subdirectory or a file.
Pretty frustrating.
Anybody know how i can install the program?
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
How did you mount?
Reply 2 of 5, by eL_PuSHeR
*** Moving thread to DOSBox Games/Apps. section ***
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 5, by Aidan1234
The Disc has a separate folder for Win95 and ms dos. IN the MS dos folder was the instalation for Ms dos.
I mounted it like this
mount c c:\dos
then in C:\Dos\ i typed 'install'
After that it said i had an error in which the program could not create a new subdirectory needed. I think because you can not edit files or folders that are on a disk.
Do i need to put all the info on the Disk onto a floppy and mount the A drive?
I will try to figure out the error code Number.
Reply 4 of 5, by MiniMax
Rank Moderator
Moderator
Disc? What disc? The CD-ROM with the game?
Try this: 60 seconds guide to getting your game to run in DOSBox
_________________
Reply 5 of 5, by Aidan1234
Yes, the game disk.
Thanks, i will try that.
