Laser Light
First post, by Thend
when i try to play laser light it always sais press any key to continue...
i hit a key, the screen flashes and gos back to Z:\
HELP!!!
EDIT Removed link to Abandonia. We do not support so called "Abandonware" here. - DosFreak
Reply 1 of 7, by eL_PuSHeR
Works fine for me here.
Using DOSBox 0.65.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 7, by Thend
I also have 6.5. dos it say press any key to continue for you?
Reply 4 of 7, by wd
Rank DOSBox Author
DOSBox Author
Please type EXACTLY how you mounted the drives, how you start the game etc.
Reply 5 of 7, by Thend
okieday
z:\>MOUNT c c:\games\laserlt
c:
c:\>Ll.exe
got it 😀
Reply 6 of 7, by eL_PuSHeR
This game is probably coded using Turbo Pascal and it's very simple. Something must be wrong with your DOSBox configuration. It shouldn't be that difficult to run this game.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
Yes, it's working for me as well.
What OS are you on? Did you change the dosbox configuration somehow?
