First post, by Sando
Whenever I try to open the game or install files for Lemmings, the setup program runs as normal, then after the last screen, a Black error box appears with the message:
ERROR
"Unable to Open File for input"
CD Lemmings installed
Press and key to EXIT
I have no idea how to fix this, I've tried mounting the CDROM drive and the folder i want to install to, but this doesn't help, and neither does using the ioctl option.
None of the setting in the set-up program help.
I'm mainly using D-fend, but I can't make it work under DOSBox itself either.
Any help Much appreciated
Sandy Scott
Windows XP SP2
2 GHz Celeron on Asus P4S800-MX
512 MB DDR, GeForce 4-MX, Creative Audigy 2
Lemmings 2: The tribes (on the same CD) installs and runs with exactly the same settings, all i did was change the game exe path from the lemmings 1 path to the lemmings 2 path on the disc.
