First post, by sir hagorshack
PLEEEZE help this poor SOUL!
(im trying to get the file i downloaded from home of the underdogs to work)
ok so i tried running it on DOSBOX but it says it "can't locate the CD"
and when i try playing the DWB.BAT file with VDMS but there is no sound
then i read that you can get sound on DOSBOX if you hit CTRL+12 or CTRL+11
a couple times.
so im trying to get it to run on dosbox but as i mentioned it "can't locate the CD" this is a CD-RIP by the way and it is supposed to be on the C-DRIVE which it is. so what am i to do?
