First post, by Efialtis
Hi,
I opened a post for this game in the DosBox section, finally I discovered that it seemed to work better with VDMSound but now I find that there are still problems. Now the sound doesn't stutters, but it sounds like there are interferences, you know, like when you put the radio on and the channel is not properly adjusted. You hear little garbage with the music or speaking, I don't know if i've explained it well, sorry, but I hope you can help me. ¿What should I do? ¿There is anything I can change in the VDM preferences?
