Dragon's Lair
First post, by Seanpatrick
I tried running the Dragon's Lair (DOS Version from 1993) through DOSBOX, but when I choose the options, the screen goes black and freezes, or the game closes and I get the following error message:
ASSERT FAILURE!: (zopen("a09912.dat")) at line 1600, file W"-~
http://www.takeforum.com/serinea
Reply 1 of 6, by Seanpatrick
Hmmm, I asked this question over two months ago, and nobody has replied...does anyone know what the problem is?
Reply 3 of 6, by wd
Rank DOSBox Author
DOSBox Author
That's correct, so what? I'm tempted to close threads which are
bumped by useless commenting. If somebody has a solution to the
problem he'd have posted it.
Reply 4 of 6, by Seanpatrick
I can only get the game working if I make a special DOS Bootdisk by putting a lot of files from different places together, but then I have to log off Windows and I still don't get any sound. I'd use the bootdisk, but I lost it and I can't remember where I got all of the files.
By the way, WD, there's a difference between not having an answer and completely ignoring a post until it's on page 31, where nobody will find it.
Reply 5 of 6, by eL_PuSHeR
I would not press my luck if I were you... 😁
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 6 of 6, by petrus929
Hi, just got it working on my PC, I also had some troubles first.
In Windows it was ok to run if from the CD directly but not from a hard disk copy (error/freeze after intro screen), so I had to play around a bit...
Copy the "/PRODUCT/FULL" directory of the CD-ROM to the harddisk (any name should do). In DOSBox, mount the directory as a CD-ROM with the correct CD-Label - example for Windows:
mount c d:\Dragonslair -t cdrom -label DRAGONSLAIR
"d:\Dragonslair" in this case is the copy of the CD or the "FULL" subfolder on the harddisk.
On windows PCs the label is auto set if a CD is mounted, if you provide the CD label on Linux system it should work too. I hope this information is still useful for somebody. Have fun!
