First post, by qv90
This patch enables the Dos interrupt Int 21H function 57h-01h.
DOS programs as Norton Commander were able to compare directories (based on size and last modification time) and then synchronize those directories. To perform this task, you need this interrupt function (which is not yet implemented in DosBox 0.65).
You may download the patch at http://www.qv90.de?sw&F8=1&CI=1&FI=3
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
hmm i played with that myself lately as well.
I had a lot of problems with the daylight saving over at my place.
Water flows down the stream
Reply 2 of 8, by qv90
yes yes this was quite hard to track down 😀 to be honest - the solution I provide is developed with Visual C++ on WinXP. I'm not able to check the funcionality on Linux.
Let me know if you encounteres any problem.
Reply 3 of 8, by qv90
bug fix implemented. new version
Reply 4 of 8, by ykhwong
"Cookies not enables - function unavailable" ?
I am using Internet Explorer 7 (rc1). Do I need to login to get a patch?
Reply 5 of 8, by qv90
No. Cookies were used for navigation purposes (used by download manager). If you temporary enables cookies, you can saftely remove all cookies after downloading software.
Reply 6 of 8, by jal
It would be interesting to combine these with my not officially released patch for local DOSbox date/time (see CMOS clock patch (dates not changing when left overnight)).
JAL
Reply 7 of 8, by qv90
When loading file timestamp in DosBox (0.65) it is converted using "localtime()" to sync displayed timestamp with XP and taking care on dayligth saving. My patch takes care about it by reconverting time to gmt before updating host file timestamp.
At no point Dosbox date and time functions were used. So I see no overlapping (without checking your code patch). Should both work.
