First post, by Smurf
Hi,
I'm a newbie for Dosbox 0.65 and tried this weekend several old Dos games with CD swapping under Alcohol 120%, worked fine. Mounted a virtual CD and by hotkey I can change from one CD to the other.
Then I came to Under a Killing Moon (access), who worked fineon my old PC years ago. Installing and starting no pb, but as soon as Murphy goes to find his first job.... I get the message in the game "Memoire insuffisante" (Out of Memory) and if I go back to DOSBOX "Erreur DOS rencontrée" (DOS error happened)
I changed everything, TEX3 by TEX197, XMS, EMS and UMB settings, memsize from 16 to 64 and even on another PC, always the same message. Yesterday evening I tried to make a direct Imgmount of the 4 CD's (iso_format), but still with the same result. Is there anywhere somebody that got this kind of problemes? Who can point out my mistakes???
Thanks in advance.
