First post, by Phil2
Hello All,
First of all I'd like to congratulate the developers of DOS box.
It's been great being able to run Turbo Pascal again on my Mac!
I've noticed a small bug with the OSX 0.65 version.
If you keep your finger on the 'a' key it types an 'a' character once and then turns into '+'. I'm using a Powerbook G4 laptop but I also get the same error when I plug in an Apple keyboard via USB.
Anyway, I thought I'd just report this to see if anyone else gets the same error.
Many thanks,
Phil2
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
Does it repeat the + sign? How does it behave when you
set usescancodes=false in dosbox.conf if you didn't already?
Reply 2 of 3, by Phil2
The + did repeat but after I tried your set usescancodes=false suggestion it works fine.
Thank you very much!
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
I thought osx had it disabled by default...
Anyways, the character turning into a + is a bit odd, have to look into this
but i don't really see any reason why it should change at the moment.
