First post, by sonwon
I am wondering two things.
1. will pDosBox development continue?
2. will someone work with me to resolve this error.
DosBox on Linux works find with this program. I would like it to work with my PDA.
Thank you,
SonWon
Reply 1 of 7, by sonwon
FYI, pDoxBox 1.1 also does not work so I suspect an update to 0.65 will fix the problem.
Thank you,
SonWon
Reply 2 of 7, by DosFreak
1. Who knows. It would probably be best to ask the author of pDosBox. The DosBox devs have nothing to do with pDosBox.
2. As I stated above. Ask the author of pDosBox.
Make your games work offline
Reply 3 of 7, by sonwon
Hmm, The author of pDosBox says he turned over all of the source code to DosBox since he cannot continue to develop pDosBox.
Is there someone else who might know what happened to the source?
Thank you for the reply,
SonWon
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
I have to source of the pDosBox.
The development will continue if somebody wants it too.
Water flows down the stream
Reply 5 of 7, by sonwon
Do you know which programming tools pDosBox was developed in?
What skills should I have to take a shot at updating pDosBox.
I've programmed in C, C++ with embedded Visual C++ and also Watcom C DOS applications.
Thanks,
SonWon
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
it's written in C++/C just as DOSBox.
if you want the source send an email mentioned on our homepage.
Reply 7 of 7, by sonwon
eMail on the way. I'll add you to the spamblocker.
Thank you,
SonWon
