First post, by prmusic
Hello folks.
I have seen in the Games compatibility list that Dragon's Lair seems to be compatible with DOSBOS 0.62. So Far I was not able to run it.
The Game must not be installed - it is playable directly from CD.
Starting the program in DOSBOX 0.65 (tested with 0.62 as well) will bring the configuration screen of the program. After choosing the configuration and pressing 'enter' the game should start but it causes a black screen only.
I played around with the settings via D-Fend v3 without any success.
I got no error. Does anybody has generic recommendations how to start analysing the problem?
Thanks
Frank
System: AMD 64 3700+
OS: WinXP Pro (SP2)
Video: GeForce 6600 (256MB VRAM)
Sound: Soundblaster Audigy2
Btw. I got SpaceAce up and running with DOSBOX (same manufacturer) but the same DOSBOX settings didn't worked for Dragon's Lair
