First post, by Jay2
Hi!!
I'm running ANABAT 6 from this web site:
http://users.lmi.net/corben/anabat.htm#Latest_Versions
I load a file (any BAT call), and each time I load a new file, it grows the ram usage by around 2MB.
I've attached a file so anybody can test. I've tried this on a P4 - 630 with 1 gig ram, a P4 - 630 with 512 MB and both have a ery different hardware configurations.
I've tried disabling all I can in DOSBox.conf (including EMS / XMS / UMB), and it still does the problem.
To recreate the bug:
Just copy the ANABAT6.exe file from the download site, with the file attached in a directory
-run DOSBox
-press ctrl-alt-delete to see memory usage under "performances",
-in Anabat press "shift-L" to load a file, choose the file and press enter
re-press shift-L to reload the same file, again and again.
The bug does not appear when running Anabat in windows' "cmd". Neither when runned in true DOS, as I've run it in system with under 8MB ram without problem.
So, why does DOSBox take 2MB each time I relaod the file???
Thanks,
Jay2
