First post, by cmXsevenfoldXmc
Hi there,
I've gone through the whole process of installing it by mounting the right drives and such, and I've gone father into the loading process for the game as I ever have in the past couple of days. However, when Crusader: No Remorse is loading, it gives me this random problem (and I've checked around the forums for an answer and I haven't gotten an answer yet). The problem I get is the following:
Running with full installation.
Loading: [.....CRUSADER: No Remorse
Out of memory in file GRAPH\VPORT.C, line 103
I'm just one problem away from reuniting with my old old hobby (been 7 years since I last played Crusader: No Remorse)
And btw, yes, I'm installing an original copy, not an illegal download.
I'd greatly appreciate any help that I can get!
Thank you,
-cmXsevenfoldXmc
Reply 1 of 3, by cmXsevenfoldXmc
Corrections:
I meant to say "farther" instead of father.
Also, I did read the README, and found nothing there.
-cmXsevenfoldXmc
Reply 2 of 3, by Xian97
I have played it up to the 4th mission recently.
Settings I used regarding CPU and memory:
[dosbox]
memsize=16
[sdl]
output=surface (I had trouble with it freezing with OpenGL)
[cpu]
core=normal (also works with dynamic)
cycles=auto
[dos]
xms=true
ems=true
umb=true
I also made an iso of my original cd and mount it with imgmount
imgmount k d:\dosgames\doscds\crusader.iso -t iso
Most of the errors I have seen with Crusader has been people not mounting their cd properly, but they usually got an error like
FILE/FASTFLEX.c, Line 38 error
I hadn't ever seen the error that you had posted.
Reply 3 of 3, by cmXsevenfoldXmc
Thank you very much!
I have been playing around with the settings and I had realized that it was because I had XMS off... Once I turned it back on, it went in perfectly!
I'm truly amazed and still in shock that I was able to play once again the game that I thought I was never going to be able to see ever again.
Thank you guys!
Now on to speding up the game a little bit hehe, lags sometimes.
Thanks again!
-cmXsevenfoldXmc
