First post, by DemoLover
Hello people! I'm back (after a long time) with a new problem to throw at the DOSBox dev team ๐. Mortal Kombat 1 runs perfectly but it cannot detect soundblaster in anyway. It doesn't even ask you about your IRQ, DMA channel etc. so you can know the ones it's checking ๐. It just says 'cannot initialise soundcard.' I'm using DOSBox 0.65 btw on Windows XP.
I was able to play it with sound on a virtual PC running windows 98 while borrowing the SET BLASTER line from DOSBox and it worked (although the sounds were played very jittery.)
Anyway, I was wondering if you could check it out. I can attach a copy of the game to my next post if you want ๐. Anyhow, thanks again for this awesome emulator. MK2 was awesome with DOSBox =).
