First post, by Lachris
Hi I´m new to this forum... In a couple of days, I have tryed to get Carmageddon 1 to work in dos with LAN.
I have det orginal version, and use XP SP2, and use the glide patch.
Here is the thing:
There is the windows verison with bad gfx, but here LAN is working...
There is the dos verison with good gfx, and with no LAN.. (Good gfx: Glidos and the other glide thing)
Is't possibil to make C1-dos to work with LAN???!?! and with good gfx?
I know the windows version not work with glide.
I think i need some Dos drivers, but how to install them so it works in XP with good gfx i C1?
I use "Realtek RTL8139/810x Family Fast Ethernet NIC" and if so, what about others? so i could play with my freinds 😀
Should i install it in af autoexec.exe file? there is a file in windows\system32
Or could I load in a *.bat file before it stats the game?
I have read this but make no sense (http://www.tower.net.au/~robsol/carma/carm_faq.html#network)
and i have search the hole net and found nothing about this problem.
Thank you 4 your time 😈
