First post, by ldd2871
Hello,
I have a DOS charting application (GannTrader) that run under DOS.
It does run under win XP but only 640x480. When I select higher resolution the video messes up.
Under Win 98 it works correctly up to the max resolution.
So, I tried DOS-box. It works fine under 640x480, but also messes up on higher resolutions.
I think I need to enable SVGA on DOSBOX config, but I am sure how. If you can help I'll be grateful.
My system P4 3GHz ASUS MB, 2GB RAM, 128MB Sapphire Video WINXP SP2
Kind regards
Luigi
Reply 1 of 2, by eL_PuSHeR
You should try a CVS build with several SVGA chipsets implemented. I think Ykhwong's will do.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by MiniMax
Rank Moderator
Moderator
DOSBox SVN Builds
_________________
