First post, by happymasksalesman
I'm new to DOSBox and I kinda figured out how it works.
However I have a problem with running EWJ2 (Earthworm Jim 2)
I mounted D:\Games\EWJ2\ and I tried to run the EWJ2.EXE file in it, as I should.
But when I press enter the following line comes up
*No CDROM drives found. Make sure MSCDEX is installed.*
What should I do next?
I triend the same with EWJ1, but that has the same problem.
Hopefully someone can help me out.
