Chronicles Of The Sword, Different Sound Out Of Each Speaker
Having problems with a specific game or application? Post your problems here!
Postby DEADLY9996 » 2006-11-19 @ 03:52
Hi All,
I havn't used emulators in a while, but it is my first with DOSBox. Managed to use the guides to help me set it up. But i have a problem with sound being different out of each speaker.
It says 1 block of text out of 1 speaker and another block out of the other speaker. :blah: Any suggestions to the problem?
Thanks
DEADLY9996
Re: Chronicles Of The Sword, Different Sound Out Of Each Speaker
Postby eL_PuSHeR » 2006-11-19 @ 11:09
*** Moving to DOSBox Games/Apps. section ***
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
User avatar
eL_PuSHeR
Moderator
Postby DEADLY9996 » 2006-11-19 @ 21:36
o i thought i posted it in there, sorry
1: ASUS A8N32 SLI DELUXE
2: AMD FX-60 Socket 939 Dual Core
3: Corsair 2x1GB
4: ASUS 7900GTX 512
5: Standard Nvidia Chipset NForce 4
6: Windows XP Pro SP2
7; Chronicles Of The Sword
8: Movie Sequences Fine, just during game. Also says blocks of text they shouldn't be said, but it's limited to the spcfic area that i'am in
9:SoundBlaster 16
10: Video mode (Software, OpenGL, Direct3D, or Glide, and resolution) = ermm not sure
# Version of emulator (for VDMSound, probably 2.0.4 or 2.1.0; for DOSBox, 0.58+) = Latest version as from 17/11/06
# Steps already attempted to solve the problem (please say you've read the README if you haven't, and READ IT IF YOU HAVEN'T!) = Changed a few things but they cleared up Game Speed not the problem, not sure exactly what other settings do, so i left em as default
DEADLY9996
Postby wd » 2006-11-19 @ 22:34
0.58+ means you tried 0.65 as well, right?
Does it only happen with this game?
wd
DOSBox Author
Postby DEADLY9996 » 2006-11-19 @ 23:59
i have just tried the latest , 0.65, i copied that info from another post saying what u guys needed.
And i havn't tried any othergame, this is the only1 i want to play
DEADLY9996
Postby vasyl » 2006-11-20 @ 00:09
What's in [sblaster] section of your dosbox.conf? Does it match whatever you've entered in game setup?
Try using different Soundblaster type or switch to Gravis Ultrasound.
vasyl
Postby h-a-l-9000 » 2006-11-20 @ 00:11
Wasn't there an issue like that with the left/right CDROM audio channel?
1+1=10
h-a-l-9000
DOSBox Author
Postby Swain » 2007-9-12 @ 21:14
i have exactly the same problem..... please help us :/
Swain
Postby cupra4t » 2009-2-26 @ 17:47
Hi everyone.
I have the same problem with the audio in this game.
if you run the game in a old pc with the specifications
of the game , runs well, but in new pc's apears the sound problem.
the issue is caused by the audio extraction, called qsound, that isnt emulated by dosbox.
Is possible that dosbox coders/programmers add this feature to a new release of dosbox?
is the only way to solve this problem.
Thanx in advance.
cupra4t
Postby wd » 2009-2-26 @ 17:56
What audio device does qsound use?
wd
DOSBox Author
Postby cupra4t » 2009-2-26 @ 21:24
sound blaster awe.
cupra4t
Postby wd » 2009-2-26 @ 21:31
If it can use sb16 i don't see a reason why it should not work.
What you mean by "audio extraction" i don't know.
wd
DOSBox Author
Postby cupra4t » 2009-2-26 @ 21:53
Sorry if i dont know explain the problem.
The game uses qsound tecnology and the problem is that dosbox needs emulate the qsound chip for hear the correct audio.
cupra4t
Postby wd » 2009-2-26 @ 22:00
Don't know if there is any information available about this chip (is it awe-specific?)
Yet i'd assume that this game would work without that chip as well as the
other sound devices (sb16) were far more common.
wd
DOSBox Author
Postby cupra4t » 2009-2-26 @ 22:06
I give you more info:
QSound Labs is primarily a developer and provider of audio enhancement technologies for entertainment and communications devices and software. The company is best known as a pioneer of 3D audio effects, beginning with speaker-targeted positional 3D technology applied to arcade
The first Q-enhanced PC product from Sony Interactive will be "Assault RigsAssault Rigs is an Action game by Psygnosis, released in 1995 for PC, PlayStation 1 and Sega Saturn. The game's based in the future, where real sport has been overtaken in favour of virtual sport. And everyone's favourite is Assault Rigs.
Sony's second offering, "Chronicles of the Sword" Chronicles of the Sword is a sword and sorcery fantasy point-and-click adventure game with arcade elements, created and published by Psygnosis, and initially released in 1996 for DOS and PlayStation systems.
Also currently under development is the most realistic "Formula 1" racing game to date. It is expected to be available by April, 1996.
cupra4t
Postby wd » 2009-2-26 @ 22:10
Still keep an eye for some configuration option to not use awe/qsound at all for this game.
wd
DOSBox Author
Postby cupra4t » 2009-2-26 @ 22:14
wd wrote:Don't know if there is any information available about this chip (is it awe-specific?)
I assume thats a specific chip for the awe, there are qsound chips for dvd players too.
cupra4t
Postby cupra4t » 2009-2-26 @ 22:18
wd wrote:Still keep an eye for some configuration option to not use awe/qsound at all for this game.
the problem is the same in sb/sb16/awe and gravis. the game needs this chip to do a 3d sound.
if you take a look in the page of qsound labs and see the q sound chronology:
1993
IBM licenses QSound for the MWave technology platform
Creative Labs licenses QSound for use in its chipsets and PC soundboards, including SoundBlaster 16 and AWE 32
QSound and House Ear Institute work with Starkey Laboratories to manufacture and market hearing aids. Goal: restore user's ability to listen selectively in noisy situations
First Sega CD-ROM games released in QSound. Capcom releases "Super Street Fighter II" with QSound.
cupra4t
Postby ripsaw8080 » 2009-2-26 @ 22:52
SoundBlaster 16 first came out in 1992, so if the tech was licensed in 1993, only later models could have hardware-based QSound processing, possibly the ASP line.
According to Mobygames, the game supports SBPro, which came out in 1991. If you can't disable the QSound processing directly as an option, what about configuring both the game and DOSBox for SBPro?
User avatar
ripsaw8080
DOSBox Author
Postby wd » 2009-2-26 @ 23:02
If Qsound is bound to ASP/DSP processing of the sb16+ then this is very
unlikely to be emulated as the documentation is extremely sparse on that.
wd
DOSBox Author
Next
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 0 guests
