First post, by Hazekel
- Member
I did a search and couldn't find this, although your search engine isn't the best ...
Anyway, I am trying to run an old PC game called Asterocks (an asteriods clone). When I load DOSBOX manually it seems to work fine, but when I create a bat file (using default DOSBOX.CONF) I get "program too big to fit" error and it exits DOSBOX before loading the game! I have triple checked everything I can see and there does not appear to be anything out of place or mispelled. What on earth could cause this?
