DosBox for Linux
First post, by hajime
Hi friends...
I wanted to ask if DosBox 0.65 is coming for Fedora kind of Linux more
less soon, or if there is no plan to release it?
Thanks in advance 😎
Reply 1 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
as much as people say google went evil, you can still use it for finding stuff on the net:
http://rpmfind.net/linux/rpm2html/search.php? … em=fedora&arch=
looks to be what you are looking for.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 4, by hajime
Thanks so much mate! I appreciate ur help a lot.
But how curious, it told me this after installing it:
[root@localhost DOSBox065]# yum -y install dosbox-0.65-3.fc6.i386.rpm
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
base [1/2]
base 100% |=========================| 1.1 kB 00:00
updates-released [2/2]
updates-released 100% |=========================| 951 B 00:00
Reading repository metadata in from local files
Excluding Packages in global exclude list
Finished
Parsing package install arguments
Examining dosbox-0.65-3.fc6.i386.rpm: dosbox - 0.65-3.fc6.i386
dosbox-0.65-3.fc6.i386.rpm: does not update installed package.
Nothing to do
Does version 0.65 for Windows have many updated things?
Reply 4 of 4, by dougdahl
Try it without the "-y". That prompts the install to assume yes to every question. It's likely that at some point there is a question "Do you wish to upgrade an existing install?" or something like that.
