First post, by DosFreak
This only appears to happen if you play the game and then exit back to the menu.
In the debug window it say's:
"INT10:Function 12:Call 30 not handled"
but according to the properties of the .png I just took the screen is 640x400.....
Same thing happens with CD-Man 2.0
    6.13 KiB
Make your games work offline
Reply 1 of 3, by red_avatar
I'll try this for myself when I get home later today - I have CD-Man on an old shareware disk somewhere at home so I can test that too - it might be different from the versions floating around.
Reply 3 of 3, by DosFreak
I noticed today that the game screen is 640x350 while the menu screen is 640x400.
When you run the game in NTVDM it looks like the menu screen is running at 640x350.
When you go to the other menu options and choose them they only update the upper 350 lines of the screen and not the lower 50. heh.
