First post, by parodipb
I'm a new user of DosBox. I've chosen it because I've to run an old DOS Application (written in DB3) on my WinXP PC.
Inside this DB3 application (unknown developer) there's the possibility to print some records. I guess that the application "wants" a parallel printer connected to LPT1: port.
I've 2 questions:
1) I could find a parallel printer and connect it to the PC parallel port as LPT1:. How can I "see" LPT1: directly inside DosBox (is it possible ???) ???
2) At the moment my printer is an USB one. Is it possible to use it directly inside DosBox ???
