First post, by HARNO
Touche - Adventures of the 5th Musketeer
Ok i finaly managed to get a properly ripped version with voices and music, this version was a 433.353KB .bin file, so i had to mount it in dosbox using imgmount d: c:\advent~1\touche\touche.bin -t iso
I then installed the game to the same dir, now im using a .bat to mount the image and start the game every time i play the game, it works perfectly execpt that i cant save or load... when i hit F5 and click on either save or load nothing seam to happen.
I would like to get this working before i play the game, i tryed to create a dir called save inside c:\advent~1\touche, however it dosent seam to solve the problem.
corrent files in c:\advent~1\touche are-
Touche.bin 433.353KB
Touche.bat 88byte {"imgmount d: c:\advent~1\touche\touche.bin -t iso
D:
touche -dC:\ADVENTURE\TOUCHE
C:";}
DMA.CFG 13byte
INSTALL.EXE 21,2KB
Using DOSBox-0.65 the game seam to run perfectly, execpt the save load thing. But considering that i installed the game from the mounted bin it should work.
Reply 1 of 1, by eL_PuSHeR
Ripped/abandonware and the such versions aren't supported here. SORRY.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
