Dos Batch File Command
First post, by M100
Hello, my first post here.
I am trying to run an old batch utility that uses the command "for" that Dosbox those not recognize.
Here is an example line:
for %%f in (temp2\*.e) do call bldpart %%f
Is there another command I can use instead of "for" ?
Will Dosbox support this command in the future?
Thanks,
Bill
Reply 1 of 3, by ErikGG
DOSBox "DOS" doesn't support the "for" command currently. As games don't use such constructions. The only hope is to wait for a DOSBox patch that includes this functionality.
Maybe it has been implemented in the current CVS, correct me if I'm wrong here DOSBox developeres.
Erik.
Read the new FAQ.doc
Reply 2 of 3, by DosFreak
You could try 4DOS http://www.4dos.hit.bg/
I just tried the latest build from 1/18/2007 (Holy crap it's still being developed!) and the "FOR" command seems to work.
Mmmm, green text on black background is nice. Too bad it doesn't stick. 🙁
Make your games work offline
Reply 3 of 3, by ErikGG
Thanks DOSFreak, now I know another thing I can add to D.O.G. 😁
Erik.
