Toonstruck problems!
First post, by spanner182
I finally got this game to work. 😁
BUT..........
It really runs slow, movement take a decade to do and i am a complete novice with DOSBox.
Can anyone please help me make it run smoothly, but explain it really slowly in thick man terms..... 😦
I would be very gratefull because i really would like to play this game.
Reply 1 of 4, by eL_PuSHeR
You need to set core=dynamic in dosbox.conf and increase your cycles a bit. Look into the readme file for details.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by Hazekel
Actually on DOSBOX change cycles to "auto". It works great.
If you don't know how, just "edit" DOSBOX.CONF then change
core=dynamic
cycles=auto
Reply 3 of 4, by spanner182
Where would i find the config file to edit it?
Sorry for being slow, but i really am a novice with dosbox
Reply 4 of 4, by eL_PuSHeR
dosbox.conf is a text file (you can edit it with Notepad) that is located inside your DOSBox folder. If there isn't any, launch DOSBox and enter this command: config -wc dosbox.conf
Intel i7 5960X
8 GB DDR4 (2100)
