First post, by ErikGG
Yesterday I tested Albion on the latest "official" CVS and found that the game stalls massively when a text dialog is opened, when you talk to people. Stalls of up to 2 seconds. Running around in 2D or 3D has no effect, only with the text dialog is the problem.
I also noticed that the problem only occurs when I set cycles to auto, setting a constant number of cycles has no problem at all.
The used config file is attached.
As there was no problem with 0.65, I started backtracking the problem. I've found the problem started with the CVS of 13-01-2007. The CVS of 12-01-2007 works as good as the 0.65 version.
System :
Win2k SP4
ATI mobile
1GHz
384 MB Ram
Other games work good and better as aspected.
Erik.
Read the new FAQ.doc
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
io delay probably.
I'll commit an improvement for that today.
Water flows down the stream
Reply 2 of 3, by ErikGG
Could be an IO problem, I was thinking a timer issue, as the stall happens every 5 seconds (When a dialog is open) and disabling the auto control solves the problem.
Erik.
Reply 3 of 3, by ErikGG
I tried the 04-02-2007 version and you where right QBix, the IODelay was the problem.
Problem Fixed.
Erik.
