First post, by Dominus
Dominus
Offline
DOSBox Moderator
- DOSBox Moderator
I was testing Windows 3.x installations on CVS and stumbled over this nice loop. I wanted to load the windows generated autoexec.bat in dosbox.conf's autoexec section and wrote:
[autoexec]
# Lines in this section will be run at startup.
mount c c:\doswin
autoexec.bat
Because I forgot to have it first change drive to c: I got a nice loop there. Apparently adding autoexec.bat (without pointing to an actual file) to the autoexec section makes the dosbox execute the autoexec section and thus it loops infinitly 😀
