First post, by Zero9X
Zero9X
Offline
Hello! 😀
I downloaded this from underdogs the other day and i can't seem to get it to work with dosbox. Ive managed to install it perfectly and im using the frontend d-fend. Ive managed to setup the sound and everything, but it will not load. i get the error message english.smp not found. I had to extract all the files manually because the unpack.bat doesn't work on 64bit vista, so i don't know if its because of that. any ideas? 😀
