Another daggerfall post
First post, by Lord_Freezer
I have looked at all the other posts, got the compiler, modified conf files, daggerfall works fine without dosbox but when I try to run it in Dosbox I just get a black screen, no error messages in the other dosbox window, my computer should be able to run the game fine. Any suggestions?
Reply 1 of 1, by frobme
The below conf works with Daggerfall (patched to 2.13, you MUST patch it) and DosBox CVS. I use it all the time. Obviously you will have to change the paths at the end to match your setup. I used a modified Daggerfall .cfg file for paths; the normal one is called "Z.CFG"
[speaker]
pcspeaker=true
pcrate=22050
disney=false
tandyrate=22050
tandy=off
[glide]
port=300
glide=false
[innova]
samplerate=22050
sidbase=280
innova=false
quality=0
[cpu]
cycles=max
cycleup=500
timesynched=false
cycledown=20
core=simple
[debug]
[gus]
gusrate=22050
dma2=3
dma1=3
gusbase=240
ultradir=c:\ultrasnd
gus=false
irq2=5
irq1=5
[log]
vgagfx=true
files=true
mouse=true
keyboard=true
fpu=true
dma=true
cpu=true
pic=true
io=true
bios=true
misc=true
gui=true
vgamisc=true
sblaster=true
dosmisc=true
ioctl=true
exec=true
pit=true
int10=true
fcb=true
paging=true
logfile=
vga=true
…Show last 97 lines
[printer]
height=110
multipage=false
width=85
dpi=360
printer=true
printoutput=ps
[render]
aspect=false
scaler=normal3x
frameskip=0
[dos]
umb=true
xms=true
keyboardlayout=none
ems=true
[vsync]
vsyncrate=75.023426
vsyncmode=off
[midi]
mpu401=intelligent
device=default
config=
mt32rate=22050
[dosbox]
captures=c:\games\emulators\dosbox game launcher\captures\1
language=
machine=vga
memsize=32
[sblaster]
sbbase=220
oplrate=22050
irq=7
sbtype=sb16
hdma=5
dma=1
oplmode=auto
mixer=true
[ipx]
ipx=false
[sdl]
pixelshader=none
overscan=0
windowresolution=original
sensitivity=100
usescancodes=true
fullscreen=false
fulldouble=false
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
output=opengl
autolock=true
fullresolution=original
[mixer]
rate=22050
blocksize=2048
nosound=false
prebuffer=10
[serial]
phone8=empty
phone9=empty
phone6=empty
phone7=empty
serial3=disabled
phone4=empty
serial2=dummy
phone10=empty
phone5=empty
serial1=dummy
phone2=empty
phone3=empty
phone1=empty
serial4=disabled
[vga]
svgachipset=s3
videoram=4096
[autoexec]
mount C "C:\Games\DOS\Daggerfall\"
C:
cd \
FALL.EXE dosbox.cfg
exit
