Neobook for DOS
First post, by basti007
I try to get a Neobook for DOS application running under DosBox 0.65 (not Neobook for DOS itself, but a compiled EXE from Neobook).
Actually, it works very well. The only thing that doesn´t work are longer sounds. I´m not sure, but i think, Neobook extracts these sound files out of the EXE overhead and plays them via a special application called SPLAY.EXE which is placed in the same directory as the Neobook-EXE. You can see Neobook handing over the sound file for a short time in the header of the DosBox windows (chaning the name of the EXE file into SPLAY.EXE).
These actions do not work. It just doesn´t play anything. SPLAY.EXE quits and nothing has happened. I don´t know what´s the exact problem. Short sequences of about 10 secs are played within the EXE and play correctly. So i don´t know if its a problem with the external extraction (couldn´t see any temp files extracted while these actions take place) of the sound file, with SPLAY.EXE incompatibilities itself or if SPLAY.EXE just doesn´t recognize the sound adapter (tried different already, though).
DosBox hasn´t shown any errors in the log window as well.
Anyone an idea? Any Neobook geek in this forum?
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
Tried low cycle counts and core=normal?
Reply 2 of 3, by basti007
Thanks a lot, reducing the cycles to 3000 and turning the core to "full" did the trick.
Unfortunantly, the application is quite slow now, but at least it works.
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
The next dosbox version should improve the sb detection a bit.
