First post, by JamesJoey
I installed DosBox. After adding a dos game to add.bat using SendTo DosBox tells me it requires Java Runtime Environment 1.5 or higher even though I installed Java Runtime Environment 6. Is this the wrong Java?
Thanks,
James
Reply 2 of 10, by JamesJoey
Why does DosBox tell me it does???
James
Reply 4 of 10, by JamesJoey
But, a third party front end isn't triggering this message.
As far as what version of DosBox I'm using, I have no idea. There's nothing in the program that indicates this. I was given a link from a usenet newsgroup to DosBox. I downloaded it and extracted the files from the zip to a folder called DosBox--no setup file or nothing.
James
Reply 6 of 10, by wd
Rank DOSBox Author
DOSBox Author
Can you post a reference to this usenet entry?
Reply 7 of 10, by MiniMax
Rank Moderator
Moderator
Can you open a command prompt (Start => Run ... => cmd.exe) and enter java -version:
C:\> java -version
If you have Java 6, it should say something like:
java version "1.6.0-rc"
Java(TM) SE Runtime Environment (build 1.6.0-rc-b123)
Java HotSpot(TM) Client VM (build 1.6.0-rc-123, mixed mode, sharing)
_________________
Reply 8 of 10, by Kreshna Aryaguna Nurzaman
I don't know if this could be any help, but based on my experience, if it says 'JRE 1.5' then you should use JRE 1.5 despite the 'or higher' phrase. Once I was using an application that's supposed to use JRE 1.3, and everything went awry because I was using JRE 1.4.
Reply 9 of 10, by wd
Rank DOSBox Author
DOSBox Author
He does NOT need ANY java stuff to just run dosbox. DosFreak provided a link.
Reply 10 of 10, by MiniMax
Rank Moderator
Moderator
Maybe we should start by determining which problem the original poster is trying to solve, before we post solutions?
_________________
