First post, by astroboy
Hi im using Dosbox 0.65 and when I capture a picture of "Quest for Glory 4" it is 320 x 200, is there a way to make it 800 x 600 or 640 x 480?
Dose the game run in 320 x 200 or is it dosbox that chooses this reseloution for capture?
Thanks
Shaun
Reply 1 of 14, by MiniMax
Rank Moderator
Moderator
I believe DOSBox simply captures the picture in whatever resolution the game is in. I have a screen capture of Rail Road Tycoon that is 640x400. In another game they are 320x200.
_________________
Reply 2 of 14, by Freddo
Quest for Glory 4 run in 320x200 which is why the screenshots are using that resolution. If you want to change the resolution of the screens, I suggest you use IrFanView or some other image processing application.
Reply 3 of 14, by Great Hierophant
The best program I have found for resizing DOS game screens is Microsoft Picture Viewer, which used to be bundled with Microsoft Office. Almost perfect for integer scaling.
Reply 4 of 14, by gidierre
Try VSO Image Resizer (freeware)
So Loom01.bmp a 320x200 screenshot
becomes LoomImageresizer01.bmp which is a 800x500 screenshot.
I wonder if the visual enhancement will show here as well as it looks on my screen, but I tell you it looks good to me
Moderator edit: Replaced hideous large BMP files with PNG files.
    14.96 KiB
    494.23 KiB
    217 downloads
Reply 6 of 14, by wd
Rank DOSBox Author
DOSBox Author
First of all you'll be killed because of uploading huge .bmps 😉
Please replace them with .pngs
Reply 7 of 14, by eL_PuSHeR
Here you go.
    320.01 KiB
    202 downloads
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 8 of 14, by franpa
and the output resolution is separate to what the game is running in, right? like it's a filter? so if a game runs @ 320x200 and you have dosbox set to output at 640x400... snapshots will still be taken at 320x200.
correct?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 10 of 14, by franpa
😁 my point was explaining that what dosbox outputs at isnt what the game is run at... the larger image is like overlayed yet screen captures ignore this overlay and take a pic of the original.
my website
Reply 11 of 14, by DosFreak
Unless you use ALT+PRTSC in Windows or some other screencap program. Then you can capture the scaling. Would be cool if DosBox could do this.
Make your games work offline
Reply 12 of 14, by collector
The capture in ScummVM is from SDL and uses whatever scaling the game is running with. From the ScummVM Wiki:
"On platforms which use SDL backend (Win32 and *nix included) Alt+S creates a screenshot file called scummvmXXXXX.bmp inside the current directory."
But even though DOSBox uses SDL, this does not work with DOSBox.
Reply 14 of 14, by gidierre
Neville wrote:
I use ACDSee for this. Actually, any decent image viewer / editior should do the trick.
[connecting flat from hiernamaals internet café 😵 ]
but my fatal point was supposed to be ACDSee or MS Office are no freeware, while Image Resizer is.
