First post, by pleaseiwantthem
I was using DOSBox 0.65 and I had no problem. Note that I was using the default configs.
Today I upgraded to 0.70, and now when I switch to fullscreen, my screen flickers. I know why it does that: it's because DOSBox tries to show a resolution of 640x400 or 320x200, and my digital monitor doesn't support those resolutions.
I therefore suppose that DOSBox 0.65 merely streches the screen where 0.70 use the real resolution.
I checked in the dosbox.conf file if there was some other satisfing fullscreen video modes. There might be, but I didn't find any.
As I'm at it, I suggest a feature like "Force alternate letterbox resolution" like in Adventure Game Studios for people like myself that don't support resolutions below 640x480 and also to keep the correct aspect ratio on some monitors.
Meanwhile... does somebody have a workaround? I hate playing in windowed mode!
Reply 3 of 15, by dgiglio84
I'm having the same problem. In 0.65, the fullscreen resolution would stretch to fit the entire monitor. However, in 0.70, it seems to be fixed at 640x480, which is causing black bars on the top and bottom of the screen.
Here are my system's video stats:
OS: Windows XP Home Service Pack 2
Video card: nVida GForce FX 5200
Driver version: 6.14.10.4523
...and my dosbox.conf file:
[sdl] # fullscreen -- Start dosbox directly in fullscreen. # fulldouble -- Use double buffering in fullscreen. # fullresolution […]
[sdl]
# fullresolution -- What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution -- Scale the window to this size IF the output device supports hardware scaling.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lowest,lower,normal,higher,highest.
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
# usescancodes -- Avoid usage of symkeys, might not work on all operating systems.
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=1024x768
output=surface
autolock=true
sensitivity=200
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,normal3x,advmame2x,advmame3x,advinterp2x,advinterp3x,tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: simple,normal,full,dynamic.
# cycles -- Amount of instructions dosbox tries to emulate each millisecond.
# Setting this higher than your machine can handle is bad!
# You can also let DOSBox guess the correct value by setting it to auto.
# Please note that this guessing feature is still experimental.
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=normal
cycles=11000
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401 -- Type of MPU-401 to emulate: none, uart or intelligent.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device. In Windows put
# the id of the device you want to use. See README for details.
mpu401=intelligent
device=default
config=
[sblaster]
# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the dosbox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
# On auto the mode is determined by sblaster type.
# All OPL modes are 'Adlib', except for CMS.
# oplrate -- Sample rate of OPL music emulation.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# gusrate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy Sound System emulation (off,on,auto).
# For auto Tandysound emulation is present only if machine is set to tandy.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[bios]
# joysticktype -- Type of joystick to emulate: none, 2axis, 4axis,
# fcs (Thrustmaster) ,ch (CH Flightstick).
# none disables joystick emulation.
# 2axis is the default and supports two joysticks.
joysticktype=2axis
[serial]
# serial1-4 -- set type of device connected to com port.
# Can be disabled, dummy, modem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameters for all types are irq, startbps, bytesize,
# stopbits, parity (all optional).
# for directserial: realport (required).
# for modem: listenport (optional).
# Example: serial1=modem listenport:5000
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# umb -- Enable UMB support (false,true,max).
xms=true
ems=false
umb=true
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup
Reply 4 of 15, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You should make a new dosbox.conf first.
1+1=10
Reply 5 of 15, by dgiglio84
Tried that. It's still not working.
I've reverted back to 0.65 for now, at least until I can figure out what's going on.
Reply 6 of 15, by eL_PuSHeR
Change output=surface to something else (overlay, ddraw, opengl).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 15, by Xelasarg
If I understand your problem correctly, I've experienced this behaviour in the past with 0.65, too. Like eL_PuSHeR suggested, changing output=surface to output=ddraw should fix it (at least did so for me).
"What's a paladin?!"
Reply 8 of 15, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Change fullresolution= to something your monitor supports.
1+1=10
Reply 9 of 15, by dgiglio84
Well, I fixed my screen resolution problem. All I had to do was change my monitor's refresh rate.
Reply 10 of 15, by eL_PuSHeR
Thanks for posting back. 😎
Intel i7 5960X
8 GB DDR4 (2100)
Reply 11 of 15, by avatar_58
A friend of mine is getting the same issue with Blood. He's tried setting the output to overlay and changing his refresh rate. It still happens.
Anyone have any other ideas? Why would refresh rate help one person and not another?
Reply 12 of 15, by wd
Rank DOSBox Author
DOSBox Author
What OS and how did he change the refresh rate?
Reply 13 of 15, by avatar_58
Oh well XP and display properties.
Reply 14 of 15, by wd
Rank DOSBox Author
DOSBox Author
Um fullscreen changes the resolution so better try that dxdiag tool
or wherever refreshrates can be adjusted.
Reply 15 of 15, by avatar_58
Well he tried forcing a few different rates via dxdiag and nvidia's control panel, but it still flickered at 1024x768. It works fine at 640 and 800 though.
