First post, by MiniMax
Rank Moderator
Moderator
Re: CD-ROM issues in OSX
_________________
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
Well there's also no sensefull error message if you hammer your
head against the monitor.
Reply 2 of 4, by DosFreak
But there should be....and there is if you bang your head or your keyboard.
The following is the result of me actually banging my head on my keyboard:
uij
Make your games work offline
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
You should be capable of hitting a LOT more keys at once.
Maybe unknown options could output some warning if that's
possible with the current parsing.
Reply 4 of 4, by `Moe`
It is possible, but it has to be done separately for each command.
