First post, by corpser
Problem is in Test Drive III
when I setup sound as Adlib, no problem
when I setup sound as Midi/MT32 - there is no sound in the captured avi file, but in the game it is
btw: i've installed the MT32 driver and set it under WinXP as Midi device
any suggestions would be great
thx,
daniel
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
there is no suggestion.
it's by design.
Water flows down the stream
Reply 2 of 4, by corpser
damned
okay,thanks
Reply 3 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
and when you think about it even makes sense in a way 😀
Since Dosbox only passes the midi commands through to the Windows midi device Dosbox can't capture the midi...
You'd need to record it yourself then and then manually edit the music in though that doesn't sound like fun 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 4, by corpser
yeah that works thx, i can record it via windows soundrecorder
btw: the mt32 sounds so awesome 😉
