First post, by I4ko
Hi
I may be totally dump but was unable to find the replacement for the CTRL-ALT-FX shortcuts in linux, for example CTRL-ALT-F5 is capture to video, but in linux these type of shortcuts are reserved for other things. I've tryed CTRL-ALT-5 and CTRL-SHIFT-F5, even CTRL-ALT-ESC-5 but neither was with the desired result.
I also cannot fint the answer in vaious guides and faqs.
Thanks.
