Fragile Allegiance crash
First post, by Scottly
Hi all
I'm trying to run Fragile Allegiance under DosBox 0.70. It loads up fine, but after a few minutes of play, it will crash out, and spit the following at me:
Any suggestions?
I'm running Vista, which is probably significant.
Thanks.
Reply 1 of 7, by MiniMax
Rank Moderator
Moderator
I don't think Vista plays a role here. That DOS/4GW thing is something that is/was used a lot in DOS-games by many game companies. Looks like it ran into a problem. You might want to search the forum for posts on how to replace DOS/4GW with a similar thing called DOS32A. It might just work.
_________________
Reply 2 of 7, by Scottly
I followed the instructions for DOS/32A as outlined in the thread:
[ANN]: DOS/32A v9.1.2 has been released
Now the executable won't even run, I get:
ERROR: Program requires a video card with VESA BIOS.
I assume this is something fairly easy to change in DosBox?
Reply 3 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
"transfer stack overflow" could be related to cycles=auto. Try a fixed value.
1+1=10
Reply 4 of 7, by skyrunnner
Got here the same problem
Can anyone help me out???
Thanks
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
dosbox version? os? ??? ? etc. ?
Reply 6 of 7, by red_avatar
I'm a bit confused.
I don't think I ever replaced DOS4GW with DOS32A for Fragile Allegiance. I only make the replacement if the game proves to be unstable - sometimes DOS32A creates problems too so no need to use it unless you have to.
I also never had crash issues with Fragile Allegiance but ... are you two using the REAL version or the one that's on Underdogs with the ripped animations and suchlike because THAT DOES cause a crash if you forgot to turn those off. Rips often have problems - was like that under real DOS too.
Reply 7 of 7, by skyrunnner
The lastest version of dosbox, WIN XP SP2 and the game is the "original"...you know what i mean...
Cumpz..
